Just bought a new 2024 Roku Ultra. Downloaded the app for 4th gen and was able to select my unit. Once the home screen of the app loaded, it immediately crashed and sent me back to the Roku home screen. Tried rebooting Roku, Tablo, and router and get the same result when launching Tablo app.
Have had my 4th gen Tablo for over year, still works almost flawlessly on Android device and Fire TV stick. Anyone know if there are settings that need to be tweaked to get this working on the Ultra?
Roku, wired or wireless? Tablo wired or wireless? Both on same network/router? Roku would default to 5ghz wifi while the Tablo would connect to 2ghz wifi…do you have the same name for your network? my home, or do you have myhome2ghz and myhome5ghz?
The Roku Ultra does have a wired connection, why not temporarily connect the Roku to your router wired if you can to see if it connects to Tablo. Or leave the Roku on wireless and connect the Tablo to your 5ghz wifi network. By the Way what type of router do you have?
I’ve been using the 4th generation Tablo for approximately two years with my multiple Roku Utras and a Roku 4. They have all worked flawlessly until 8 April 2026. I suspect that it has something to do with a recent software update by Roku around the same date. My Tablo/Roku symptoms are the same as you have described. I’ve deleted and reinstalled the Tablo App on all my devices multiple times along with multiple soft Tablo resets (white button on bottom of device) as well as a hard (unplug) reset. I’ve reset each of my Rokus multiple times as well without a solution. I’m sure the Roku software update no longer allows it to play nicely with the Tablo. Hopefully, these two companies will get together and troubleshoot the problem ASAP. I’ve been unable to access my Tablo content for almost a week. It is getting a little more than frustrating at this point.
After action report: Tablo’s recommended fix (Posted above) did not work (for me) Note: I have three Roku devices and this fix did not solve my problem on any of them.
Thanks for the input. Gave it a shot. Unfortunately I’m still having no luck accessing the Tablo. I’ll try to get a human from Tablo Support to walk me through the process. Not sure what the problem is. All my Rokus are funtioning just fine in all other respects.
Thanks for the tips. I tried the audio settings you mentioned but it made no difference for me. I also have audio compatibility on and can’t get the app to load. Still waiting to hear back from support.
I’m unable to access my Tablo settings thru the app and none of the recommended fixes within the Roku settings have made a difference. I’m still unable to access my tablo on any of my otherwise fully funtional Rokus. Help!
Thanks for directing me to the Tablo phone app. Apparently, my Tablo is already in Stereo ACC mode. The Surround Sound AC3 mode is off. If I recall correctly, Tablo support had me make this update more than a year ago when I was unable to play some of my library recordings. The problem I’m encountering now is different. Now, I can’t even access the Tablo home screen to get to my recordings. The Tablo Home Screen will only flash on my Sony TV momentarily and then immediately returns to the Roku home screen. Keep sending me your ideas. My ticket ID is: 540482
Question: Is it possible that my internet provider has made some security upgrade that is preventing the Tablo app from working properly? Just spitballing at this point. I ask, because the day I encountered this problem Xfinity was doing some upgrades on their system that resulted in a temporary outage for my neighborhood.
