Hi folks -
An update for the 4th generation Tablo app for LG webOS smart TVs is rolling out now.
The app should update automatically in the coming days if you have enabled auto-updates on your television.
If you have not enabled auto updates, you will see a prompt to update, or you can select the Tablo app and then select the UPDATE button to get the latest version when it is available for your television.
Here’s what you can expect:
Tablo App for LG webOS Smart TVs (4th Gen) Update (v. 1.71)
- Performance enhancements to Tablo device discovery/selection, search, and the in-player content tray
- Fix for the behavior of the Recent filter on the Live TV Grid to show 10 most recent channels vs. 5
- Other bug fixes, stability, and performance improvements
Call For Beta Testers
Starting this year, a new LG platform program will enable us to beta-test app updates with users. If your primary Tablo viewing device is an LG smart TV and you would like to join the Tablo beta program, please sign up using the link below:
If you have any questions or encounter problems, please post them below or touch base directly with support.
