An update for the 4th generation Tablo app for LG webOS smart TVs is rolling out now.
The app should update automatically in the coming days if you have enabled auto-updates on your television.
If you have not enabled auto updates, you will see a prompt to update or you can select the Tablo app and then select the UPDATE button to get the latest version when it is available for your television.
Here’s what you can expect:
Tablo App for LG webOS Smart TVs (4th Gen) Update (v. 1.6.5 - Build C950B2)
Fix for fast-forward and rewind functions during playback of live OTA TV
Fix for rare issue where Live TV screen clock could display the wrong time
About This Release
Please note that during live TV playback, it can take approximately 60 seconds before the ability to fast-forward and rewind is available as the app works to build a buffer of video.
Call For Beta Testers
Starting this year, a new LG platform program will enable us to beta-test app updates with users. If your primary Tablo viewing device is an LG smart TV and you would like to join the Tablo beta program, please sign up using the link below:
I updated yesterday and my app version shows C950B2. I have an LG C9. I’m still not able to ff or rewind live TV. The bar just keeps moving like before.
For anyone else having this issue, you have to be watching the channel for a couple of minutes before the bar to rew/ff starts working. You can pause right away, but the bar will keep moving back and forth until you’ve been watching long enough. I don’t have this issue on my iOS and Android device.
As always, the update works great… for about a week. Then back to the same old, same old: SBBOD (spinning blue balls of death), can’t connect, this is taking too long, reset your Tablo, etc., etc. Happens every update. Well, it was nice while it lasted.
Library, Live Grid, and Home. If I run another app for about an hour and come back to it, mostly it will be OK. If I force it to keep trying it will eventually tell me to reboot the Tablo and reconnect.
Make sure you have downloaded the correct table app. You want the blue background with white letters. BTW, mine has settled down again after a few days of spinning and is stable again. I can only guess, maybe it is not the app but the servers? Just happy it is working well again.
If it ever sits there spinning longer than it should, just hold down the back button until the app exits and then reload it. For some reason, it sometimes ‘times out’ and no longer works until you close and reopen.
If only. If I do that and the app relaunches I get the spinning blue ball of death, This is taking longer than expected, Disconnect. The app relaunches again and then I get Failed to Connect to Tablo (even though I am hardwired to the ethernet). Then I have to get up and reset the Tablo physically to reboot it, wait, rescan, and reconnect. This happens about once a day. Very annoying.
I bought a 4-pack of smart plugs after Christmas after a season of snaking behind the tree to flip the power cord. Now I’ve got them all over the house. Your suggestion to use one to power cycle the Tablo is perfect.
