Hi folks -
An update for the 4th generation Tablo app for LG webOS smart TVs is available.
The app should update automatically in the coming days if you have enabled auto-updates on your television.
However, certain TV model groups may experience delays in receiving the app update due to changes to the app distribution platform by LG.
If you have not enabled auto updates, you will see a prompt to update or you can select the Tablo app and then select the UPDATE button to get the latest version when it is available for your television.
Here’s what you can expect:
Tablo App for LG webOS Smart TVs (4th Gen) Update – (v. 1.6.1) December 18, 2024
• Fix to ensure playback position is maintained when resuming an in-progress recording
Call For Beta Testers
Starting in 2025, a new LG platform program will enable us to beta-test app updates with users. If your primary Tablo viewing device is an LG smart TV and you would like to join the Tablo beta program, please sign up using the link below:
As always, if you have any questions or encounter problems, please post them below or touch base directly with support.
