Tablo Antenna Power Boost
Is there a booster for the window antenna? With the storms here is Fort Myers, the programming pixelates really bad. The stations are not that far away and the antenna is facing the correct direction.
I don’t think a booster will help you out, when I was living in a house I had the Antenna in the attic and never had a problem with the weather but now am living somewhere else and have the antenna all the way to the top inside a closet and noticed when it rains it affects the signal.
You can buy an Antenna Amplifier and see if it helps but since you are saying you are close to the towers I don’t think is need it, maybe a antenna reflector would work better?
ohh maybe an antenna LTE/5G filter will help too.
One other question, the last time the internet went offline it didn’t switch or ask to play offline. Is there a setup for this.
No, offline mode should be automatic.
Most issues like this originate in the (window) antenna. Get a better antenna - an additional amplifier (the Tablo already has one built in) will likely only amplify the problem.
