I have the Tablo Dual Lite and the HDHR duo - it is just the dual tuner.
I have it set the Tablo to highest quality on both live and recorded… The difference is not huge but it is noticeable especially when it comes to rendering text the fonts are jagged… and sometimes there is a hiccup in streaming and there is a little delay when changing channels… As noted in total these are not horrible, but I found the HDHR to be much sharper and quicker also no buffering. I use an AppleTV for this
I could mess with the settings and I am sure I could get it to work better, but as with somethings I had no way to demo a system without buying and trying…
This is in no way a condemnation of Tablo, I think overall it is a great system and probably works for most people but since I have seen the differences I like the HDHR better.
Which lead me to my question, I really wanted to find a use for the Tablo since it does meet the all in one criteria… and since it can only record what it is plugged into, I cannot just use it as a DVR…
But I guess the other question would be (and I am sure I know the response) if I set the Tablo up on a second antenna, and connected it to the network I could still use it as a DVR only (i would still use the guide and all but not watch live tv) and it should work fine as far as not having issues with multiple tuners on the same network ?
Yes I may still have the same resolution issues it already has but if this is just a recorded show it may work just fine vs live tv
Any Thoughts
Thank You
