Tablo 4th Generation Reboot
Ability to reboot Tablo from within settings.
Not available. As others have stated before, 1. if there’s an issue where you need to reboot, chances are you won’t have access to the Settings in the app anyway and, 2. you can get around this with a cheap wifi plug and do it remotely and on a schedule.
This a feature that could be helpful at some point and I know that it currently doesn’t exist, that’s why it’s a request.
I have a few of those plugs around that have the ability to toggle the power via a fob. I will connect one of those just in case for the time being.
