Tablo 4th Generation Bricked
My Tablo is totally bricked. I can’t find it via Ethernet or WiFi. Everything was fine yesterday. This is very frustrating!!
Have you tried doing a hard reset?
Yes, and I’ve power cycled both the Tablo and the router
Does My Status - Tablo TV know about it. Does your router show it as a connected device.
No connection. I’ve tried both Ethernet and WiFi and it can’t find it
Just because the client app can’t find it doesn’t mean it’s bricked.
It says: A Tablo device has been found on this network, but it has not been registered
So, what do I do?
Ok, I started over by reinstalling the app. Seems to be connecting now
Sounds like the tablo server no longer thinks you unit has completed setup. If it has completed setup it sounds like a tablo server issue. It may or may not clear up without contacting support.
It’s all good now! Whew
