My new 4 tuner Tablo 4th gen sometimes takes over 2 mins to start on a Roku Ultra. Might be only when it’s recording. Is this normal?
Hi @larry_c Sorry to hear you’re running into this.
When you say ‘launch’ do you mean to open and get to the home screen? Or when you start playing back a channel?
Launch = Open the App. If I give up after a minute, go back to Roku home and try again, it usually works.
Larry
When you’re done with the app, do you exit it or leave it running in the background?
What do you mean “running it in background”?
I think they meant backing out of the app until it asks you to exit, or just pressing HOME and going about your day.
