it used to work. now it doesnt.. likely something in the latest chrome os build
Hi @mike_winslow,
Unfortunately, we’ve never had a 4th Gen app for Chrome. Have you been using a thrid party option?
I have an Asus Chromebook and Tablo 4th works. It runs the Chrome OS.
Are you running the Tablo 4th gen Android app on your Chromebook?
nice answer . very useful. no, downloaded from google play.. who’s fault is that.. perhaps you may want to find out why it stopped working anyway. ok?
proably until you get the next update for chrome os
I’ll translate @TabloTV 's response…
Tablo gen 4 does not support any web browsers.
If a web browser does work with your Tablo gen 4, great, but Tablo will not fix any issues you have using them, since they do not support them.
Legacy Tablo supports the following web browsers:
Mozilla Firefox;
Apple Safari
Google Chrome, and Micosoft Edge (and Internet Explorer) Web Browsers stopped being supported for legacy Tablo a long time ago.
https://support.tablotv.com/hc/en-us/articles/360046912812-Which-Browsers-Can-I-Use-With-Tablo
Well, in fairness, you just said ChromeOS, which unless you specify you are talking about the Android Tablo app that can be used on a ChromeOS machine that supports Play Store/Android apps, would imply you are talking within the Chrome browser since it’s a ChromeOS machine.
Assumed you probably were, but was making the point the OP didn’t specify they were using the Tablo Android app on a ChromeOS machine.
nobody here is trying to run it on a webbrowser.. chrome os has an android container.. when you go to playstore from a chromebook - it allows you to download and install the tablo app on it.. if it’s not supported, playstore wont offer it as a choice.. I hope you guys get plenty of calls and complaints, as i believe it’s the app owners who provide a compatibility list to playstore.. in any case, what was once working, no longer works, and it has to do with the latest chromeos update.. is that clear enough now?
tell me in so many words that you dont have a chromebook.. lol.. the OP is pretty clear, but it doesnt says that the world is round either ![]()
Oh, we have 2 Chromebooks in the house. Granted, all Chromebooks made after about 2019 support running the Play Store, but not all, which is why I was saying OP wasn’t being clear enough.
Looks like it may be the Android version of the app.
maybe - but it was working, and it stopped.. if your poiunt is that it’s the ~android~ version of the app, of course it is.. some android apps are allowed to be downloaded and installed from playstore onto a chromebook, but that may be Tablo’s problem.. the fact is for those of us who ran it in the past on our chromebooks, it stoppped working with the latest chrome os build - if Tablo’s answer is that they never said it ran on a chromebook, they should find out exactly why they didnt provide that info to google playstore because chromebook users can download the app from playstore directly with no tricks.. for those who have it still working on their chromebooks - im up to build 145.0.7632.165 which is the current latest version
Oops, my bad, I read Chrome, and glossed over the OS part.
Sorry for adding to your grief.
Well I presented proof that Tablo worked excellent on my Chromebook and now it does not.
Something is going on at Tablo! As this thread progressed the Chromebook Tablo app changed two times. First it said it wanted to install my Gen 4.. haha It is already installed and was running on the CBook. I uninstalled the app, re-installed and it comes up with the Tablo’s boot screen then goes to a menu and hangs.
I just did a re-install again and the damn thing let me log into my Gen 4 and It is working perfectly. No closed captions though. The small screen of the options at 1:14 is changeable to full screen. I did that later.
This is some nefarious crap going on eh?
Here is a video I just made. Called the thumbnails Icons.hahahaa
Hope you all can watch it.
I think someone got caught with their pants down!
Jim
The Google Play store Tablo app rev is 2,05
My Chrome book OS is: 145.0.7632.216
Asus with a Celeron (R) N4500
