I have had my Tablo TV for a little over a week. Works great everywhere except my Fire HD 8 (10th Generation) tablet. Upon selecting something to watch (OTA or FAST does not matter) the screen is black with good audio. I can return out of the black screen and maneuver thru the app/guide/etc… But get the same black screen whenever I pick something to watch.
My tablo tv is version 2.2.46 and the app on the tablet is 1.0.7. Does anyone have any suggestions on how to fix this?
This sounds like an issue related to the version of Android that Amazon runs on the Fire tablet, specifically the video Codec within the Android OS version. Not sure what you can really do about that.
Since AZ’s fire tablets use older versions of Android and tweak them to their own pleasure (and restrict so many neat features), it likely could be due to that. Correct me if I’m wrong, since I no longer have any one, but from this conversation, it sound like there is a version of the Tablo app in their store. It might be worth checking out if you are able to sideload the regular Android version instead?
My fire tablet is a Fire HD 10 2023 release. I downloaded the tablo tv app straight from Amazons file site. Everything is up to date and still no video after playing channels.
The Amazon store is great for making sure that apps are compatible with your fire tablet devices. I’m just wondering if it’s the same version as the Android one (I’m using Tablo android version 1.1 with 2.2.47 Tablo firmware), since, like Google, they might hold off on releasing the true latest version just to make sure it will work on your device.
As Seeker336 mentioned…
Amazon does use older versions of Android that they’ve forked into their own FireOS. That was why I suggested trying a sideloaded, possibly up-to-date version of the app.
Upgraded from 1.0.7 to 1.1. Still have a black screen on my tablet.
When I read a prior comment about it being amazon using older version of android I thought that made sense. but now I am thinking that should not be it. If the app is in the amazon library then it should work.
I’m with ya there. You’d think an app Amazon approves in their store should work just fine (sadly, this isn’t always true). All I can decipher from this is that the version numbers are the same – TY for checking that. It still might be worth a sideloading attempt, but I have little hope that will help. Only Tablo themselves know if it’s truly the same app version. Then we could discover if the fault lies in the software, the hardware, or the OS. Two of you seem to be having an issue with the exact same device. Hopefully, that helps with the trouble shooting. Sorry, I’m out of ideas ATM.
