I too had the same issue. I’ve bought it less than 7 days ago. The USB ports are not up to specs. I had to pull the usb cable slightly back and gave it a slight turn for Tablo to power the hard drive.
Should I return it to Amazon or work with Tablo Support for return?
I started using a USB HUB. I plug the HUB into the Tablo, the Drive into the HUB, and power the HUB with the Wall-Wart. It seems to be working great. I’m not sure if relieving the power requirement from the Tablo is helping, or ( probably from what I’m reading now ) the connector combinations are more snug. I did have Tablo advise me to get a Monoprice cable, which I did order and have received. However, I’ve been hesitant to try out the new cable since this works so well.
I’m experiencing the same issue where I plugged in my 2TB WD Elements drive when trying to boot up my used Tablo. No power is going to the HDD. I tried to even charge my phone to see if the USB port is proving power and neither of the ports provide any power to charge the phone. I’ve contacted @TabloSupport with a support ticket. I think that these USB ports are dead.
@Genghis1227 We’d have to take a look at the ports to be sure - but generally @theuser86 is correct. To be replaced, the Tablo has to come from an approved retailer; e.g Amazon, Best Buy, etc.
I have the same issue with the WD Elements and the original USB cable. Sometimes it recognizes the drive and sometimes it doesn’t. If I wiggle the connection, it comes back. I have connected the drive to a PC. THE USB connection fits snugly. I ran a successful extended rest. The connection to the Tablo seems loose. It. It would seem defective to me. What is the suggested solution?
I replaced,the USB cable with a USB2 version. Picture issues went away, such as pixelation and waits. However the Tablo would reboot every couple of minutes. So I just remove the drive to see what would happen. My display issues are still gone. However I can only watch one TV and I can rewind about three minutes.
Summary: the drive performance was causing lots of other issues. Since I ran an 18 hour diagnostic on the drive with a PC with the USB cable that came with the drive, I don’t think that is my issue.
I have the same issues with my tablo and have not had any solutions yet. Tablo will never admit that it may be a hardware problem. Have my tablo for almost 1 year, lifetime member and my tablo is still unusable. getting an email response every 5 days does not work for me. I need a replacement. My hard drive work perfectly in a PC I have been reformatting it many times, read/write tests all OK. Plug it back in the TABLO usb, it recognizes there is a drive and asks to be formatted. 5 seconds later is says that there is no hard drine attached. so frustrating.
It may be for you but I have this problem for 6 months now, I told them this is a hardware problem and they still do not admit it. I tried many many times to get the unit in a remote mode and it does not work. They insist they want to remote it. I had and still have a lot of patience but this is ridiculous.
@Liviu_Imbir A remote session is usually easy to start - and it’s fairly quick for us to determine whether or not there are any hardware issues. This way we can confirm a hardware issue and send a replacement - instead of just doing the latter and seeing the same problem all over again.
If you’re having a hard time setting up a remote session, feel free to PM me or call us; we can walk you through it.
Again, I am home only on Friday and that is the only time I can call you.
How is 7:00 AM Pacific Standard time on Friday Feb. 5 (9:00AM Central Standard time) for a
call?
By the way the hard drive and all the USB cables I have works with no
issues on PC. I formatted, reformatted, read/write tests, and no issues at
all.
