My Tablo is very hot to the touch - is that normal? I carried it for the travel trailer back to the house and I a pretty sure I have the right power supply but just to make sure, can someone tell me the brand name and info on you Tablo power supply? And one last thing - it doesn’t appear that removing the check mark beside “don’t copy repeats” or what the correct wordage is works in setup as it is not recording duplicate recordings - I wanted to do this since I still don’t have an antenna(s) working that will pull in all my local stations without pixalating or just flat out not find it the station. I thought I had something working in the house but then I moved everything to the T.T. and never got a good signal for local stations which are 26 miles or less and I have tried a lot of antennas in our fiberglass T.T.- I can get 4 out of 7 but not all 7 of the main channels and they are generally in the same direction between 54 to 72 degrees fro true north - two are Hi-VHF and 3 are at 64 degrees (based on my address and zip of 29170). Can anyone help? Thanks, Jan
I use no fan, sits on a high shelf with nothing sitting on top or under it. I have never touched it to see how hot it is, but @TabloTV has stated many, many times that it runs hot and is designed that way.
I would suggest trying a directional “yagi” type antenna. I have my Tablo elevated about one quarter inch above flat surface to allow for air flow. I assume the Tablo uses a heat sink in lieu of a fan to prevent overheating.
Just a couple of 3/8" strips of wood under both ends of the Tablo. This creates airflow and should also protect furniture from getting too hot. The thickness isn’t critical and you can paint the strips black to match the unit if you like.
A couple weeks ago, I noticed…
apparently mine is warm enough for a cozy cat nap.
Oddly, she spent most of the winter in her “heated kitty bed”. So she’s well cared for if she’s actually cold.
(Yes, I’ve tried to put things in the way to deter her - anyone with a cat knows you’re a cat care-taker and have little to no control. But for the sake of the tablo I do keep her off of it.)
