I started with a DUAL LITE but bought a QUAD and want to use the DUAL flash drive in the QUAD.
I cannot read it in my PC.
WhT DO i DO?
The first thing to note is that flash drives are not recommended for use with any Tablo unit. There are several threads here with users claiming that they have successfully used certain flash drives. But just wanted to make sure you are aware of that fact in case the following instructions don’t work.
Anyway, to get back to your original question. I would suggest following the directions given on the following web site:
Hopefully this will work for you. Good luck.
