No auth. So if you can get to surlatablo on the network with the taboo, it will run
SurLaTablo 0.6 released
Adds the ccoffset style I described. Fixes fairly major bug in CONF file handling.
Oh… and this is the first release tested on OSX.
Perhaps setting up a VPN situation would work better than going direct in. If you can VPN from your remote device to your home network you have control “just like being there” and can secure things better, IMO.
0.6 - cool, I will test tonight.
How would I go about downloading manual recordings? They tend to not show up in lists. Are there any special commands to use?
@HarryR, sure they do.
surlatablo.py -q meta_type~=Manual
They’ll show up with the everything (-q .) query as well.
Or at least they should
Cool! I got a list and tried this: python c:\SurLaTablo\surlatablo.py 125653
I got a No transcoder found message. No valid transcoder name provided.
I assume that is the ffmpeg path which I did modify. FFMPEG = ‘c:\ffmpeg\bin\ffmpeg.exe’ (I’m on Windows 7)
Try this instead:
Yup you need to use the forward slash and not backslash. Silly Windows and their backslashes
Still no luck. I don’t use CCEXTRACTOR but that shouldn’t matter
You have confirmed that ffmpeg.exe is located in that path? You can manually run it from a command line?
It works both ways from command line.
I tried this and I’m getting % numbers and the name of my recording.
python c:\SurLaTablo\surlatablo.py -n -q 123781 -c
This is a good sign.
Try this instead:FFMPEG = 'c:/ffmpeg/bin/ffmpeg.exe'Here is how my settings are in my file:# Replace with full path location of your programsFFMPEG = 'i:/tablo convert/bin/ffmpeg.exe'CCEXTRACTOR = 'c:/ccextractor/ccextractorwin.exe'See if the forward slashes work. They do work in Windows 7.
Yes they do and you can prove that at a command prompt by typing cd/ from any non-root prompt
Once I see an example of code or a command, I’ve got it.
Yes you need to tell the command that you want to convert it. Although the new options file support may change that.
Since I used the non-installed method, it’s just an EXE I copied into the surlatablo folder so it’s all sitting together. I like the fact that it’s self-contained with no complex installs, no DLL-hell.
I have setup this python script to run every hour on Windows 8. It’s not as simple to setup as linux crontab but it seems to be working fine.
I see a folder created for Manual, but no temp files that I am used to seeing in tablo2go. I guess it must be in memory.
Unless you provide -k (which can be @ to place in the “normal” trancode output dir), you won’t see the temporal .ts or .srt files.
Both can be interesting, which is why I added the -k @ in particular.
Some won’t be interested in either… I’m trying to please everyone
Thanks. I’ll try that on the next one.
EDIT: I just saw the first video. Excellent result! Thanks very much
