Hi,
It is one of the fixes in .4
Thanks. I should have taken your advice and waited but wanted to test the wildcard which works great. Looking forward to .4.
Dunno where he finds the time to do that and test it, etc. Just figuring out how to access the data inside Tablo had to have taken a few minutes at least ;-)
I use his python script to backup files from my Tablo to my Windows Plex server. It also runs my security cameras recording 24/7 (Blue Iris). Works great.
SurLaTablo 0.4 is here!
SurLaTablo
0.4 -
1. You may now have a SLT_GLOBAL[‘CONF’] file (defaults to homedir
surlatablo.conf) which can be used to override the configuration variables.
This way you won’t have to keep editing the source file for local site
changes.
2. TV shows with season 0 and episode 0 (e.g. News) will now default
to s<lair_date_month>e<lair_date_day> and Unknown titles will default
to Episode - <lair_date_year>-<lair_date_month>-<lair_date_day>. You can
disable this by setting NOZERTV = False in your .conf file (see #1).
original_air_date cannot be used for this because quite often it is wrong.
3. Pathnames for output files are now santized for Windows.
4. surlatablo.py now takes arugments beyond switches which are to specify
the transcodes to do on the downloaded data. Default if not present is
just Mp4. You can override the default by setting in you .conf file:
TRANSCODER_DEFAULT = [ ‘Mp4’, ‘Gif’, etc. ]
You can specify on the command like:
surlatablo.py … Mp4 Gif Json
or
surlatablo.py … +Gif +Json
The ‘+’ means in addition to the TRANSCODER_DEFAULT values.
Use ‘-t’ option to see brief description of available transcoders.
5. Options --wcrop (-w) and --cropformat (-W) have been removed. Create and
use a new TRANSCODER_OPTS definition for this.
6. You can now use --keepdir @ to say you want to save the .ts and .srt file
in the output directory with the other files.
7. New predefined TRANSCODER_OPTS have been added, created. (see -t option)
a. Mp4 - (the norm) to create a passthrough .mp4
b. Gif - create short duration animated gif
c. Flash - create an .flv
d. HardSubs - (assumes use of -C) to embed subitles directly in .mp4
e. Shrink - create a more compressed .mp4
f. Json - create .json file containing SurLaTablo meta information for program
g. Null - used mainly to say “no transcode”, for times when you want to use
--keepdir @ to output and save just the .ts and (optionally) .srt
h. … (more)
8. Replace sanitizeFilename with sltSanitize for dynamic meta type strings
like Etitle, ESeries, essentially things that could be used in path and filenames.
Special dynamic variable Efriendly_title2 is a two line escaped string for
internal ffmpeg option use (see Gif).
9. Bug fixes… etc…
Crashed. Hope it’s something simple. Windows 8.1. I ran the update again on version 3 (different cache db location) and it ran perfectly.
I’ll take a look at this tonight. There could a 0.5 in the near future!
As a quick workaround, the Eseries assignment should have a try/pass around it. So go to line 1030 and change that assignment to:
try:<br> db_rec['Eseries'] = sltSanitize(db_rec['series'])<br>except:<br> pass
Will test in about 7 hours when I get home.
0.5 released to fix my one and only bug
@cjcox that sounds like a challenge
Actually, I kinda warned that there might be problems in 0.4… but I wasn’t expecting one so obvious.
0.5 released to fix my one and only bug :)
Obviously an ex-Microsoft employee! Just kidding, not intended as an insult, kidding!
Of course, if I were a current Microsoft employee, the program would be binary only, unmodifiable, and work only on Windows 10 (forcing you to purchase the upgrade). If I were an ex-Microsoft employee, I would be too busy with my therapy sessions to write free software.
@cjcox that is priceless.
I’ll live fix that mistake… oopsie!
Preview, version 0.6 will eliminate CCOFFSET handling it will move to options and the offset will be applied for “Live” shows. Thanks to @pundit for helping out with Live designation. Oh… and that’s a meta data addition, so requires cache rebuild… but 0.6 isn’t out yet
LOVE IT!
Don’t forget that you’d waste half the code embedding fun easter eggs…
