I am no longer able to use this program at all nor can I use Tablo Exporter.
Did the latest firmware beta update break this?
Traceback (most recent call last):
File “/root/Drive/Linux/bin/surlatablo-1.9-py”, line 2506, in
jch_ids = urllib2.urlopen(ch_ids_url)
File “/usr/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/usr/lib/python2.7/urllib2.py”, line 437, in open
response = meth(req, response)
File “/usr/lib/python2.7/urllib2.py”, line 550, in http_response
‘http’, request, response, code, msg, hdrs)
File “/usr/lib/python2.7/urllib2.py”, line 475, in error
return self._call_chain(*args)
File “/usr/lib/python2.7/urllib2.py”, line 409, in _call_chain
result = func(*args)
File “/usr/lib/python2.7/urllib2.py”, line 558, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 404: Not Found
The pains of closed companies… but what if you could get an 8 tuner box that can stream and optionally become a frontend with games, apps, surround sound and costs less than Tablo and is “open”?
Error I am getting is:
Retrieving Tablo Data (70639): [ ] 2%
File “surlatablo.py”, line 3053, in
doConvert(sl, options, basedirs, filename_pats, transcoder_names)
File “surlatablo.py”, line 1677, in doConvert
temp_f.write(ts_response.read())
IOError: [Errno 28] No space left on device
I am running “surlatablo.py” on QNAP NAS and I have 5 TB on a different location on NAS than where this is running.
I was hoping I could do -c /share/MD0_DATA/Public/
which is where my PLEX server is looking for my “stuff”. I was reading the thread but did not see anything like this mentioned.
Thank you. That is what I needed. I will have to set on up for each TV and Movies to run from time to time. I did not realize that it used . as where to place files.
I may update the config file to use it as a param.
I’m running on a FreeNAS array for my Plex and have (well had!) my surlatablo running there as well. If you are using the surlatablo.conf file to define your options you can specify the output directory with the BASE_DIRS options.
For TV shows I have mine defined as below:
BASE_DIRS={‘Default’:’./${meta_type}’,
‘TV’:’/media/tvshows/${Eseries}/Season ${plex_season_number}’,
OK, just tried it out and am still getting space issue. Not sure what has no space for this to run.
File “/usr/local/lib/PlexRipper/surlatablo.py”, line 3053, in
File “/usr/local/lib/PlexRipper/surlatablo.py”, line 1677, in doConvert
I record at 720p. A 30 min 480p show can take over 1G. I recommend a minimum of 6G, but you might need more. You might need 20G+ if you’re zapping commercials.
Now if we can get SurLaTablo to work with the latest Tablo firmware we’ll be golden. Still pisses me off they closed that door on ya without even a warning.
