I was watching TV today and all of a sudden my Tablo lost connection. I tried an unsuccessful reconnect. So I went to the device to try a reboot. To my surprise no light on, no power, no way to power it on. I tried a different power cord. No luck.
Anybody else have this problem?
Thanks Don
If you have a multimeter, the first thing I would do is check your power supply. They do sometimes go bad. If it is not that, it is possible that your Tablo has died. Mine did. Tablo does stand behind their warranty. How long have you had it?
Hi @Don_Lewellen ,
Sorry you’re running into that.
Would you consider contacting Tablo Support? They may be able to help.
