Just now, I am not getting most sub channels, only the main ones. It keeps saying weak antenna signal. Yet, when I check signal strength directly on tv tuner, all channels, including subs, show 5 bars/full strength. Anyone else have these issues? I have a 1 month old Quad with internal hd.
Well, I unplugged Tablo for 15 minutes then plugged it back in. All channels are back. Before, it would not even let me rescan channels but now it does.
Something screwy, they’re broadcast all together on the same frequency
Hope it doesn’t become a regular thing for you… the plugging/unplugging, then it doesn’t actually fix anything.
Ok, it started breaking up really bad again on Decades sub channel. Found out when I went to tv tuner directly just now, it was doing the same thing even tho signal strength was 5 bars. Must be some atmospheric interference of some sort. At least it doesn’t appear to be a Tablo issue.
