SSD Replacement Size
I need to replace a failed hard drive in my Legacy Quad. I know what’s in it is a 2TB drive, but is that the only size I can put in?
I have a 8tb seagate on mine. I save a “lot” of old movies and series. Has worked fine. As I remember that is the max you can use.
I highly recommend that you use an external SSD drive. The amount of heat generated in the legacy box will greatly shorten the life span of the drive.
External 2TB it is, then. Thanks, Guys!
