We keep getting these occasional stop in playback where the program stops and the spinning wheel happens at the progress bar.
Apple TV 4
Tablo Dual LITE
I tried reconnecting the Tablo but still happens.
Don’t know if it helps or is just a ‘pushing the elevator button’ type of psychological reaction but hitting the pause/play button a couple times will sometimes get it to start again.
When I first hooked up a Dual Lite for my aunt, she was experiencing the same issue. It spent more time buffering than playing video, making it effectively unusable. The WiFi in her house does not work very well and this turned out to be the problem. Wiring both her Tablo and her television to Ethernet resolved her issue.
I sometimes see this during playback of a program that was recorded on a channel with a weak signal. I am able to playback the video without the pause (but with pixelization) in VLC thru ota2GO. It seems that the main media player is not as robust as VLC. I don’t think you can do what I am doing on an Apple TV, I am using an Android tablet. But maybe you can… is ota2GO available on iOS devices??
Correct, I was responding to your question about ota2GO.
I don’t believe you can install it on an Android TV unit, at least I can’t install it on my Shield TV. However, don’t really have any use for it on an Android TV unit either as in that case I’d just use the standard Tablo/Tablo Preview Android TV apps.
Yeah, me neither. I was just curious. My wife says I like to take out my brain and play with it .
What I would like though, is ota2GO and MX Player on my Roku. Now that is something I could use. The standard app is okay, but I am really starting to be spoiled by MX Player!!
