SNL Consistently Wrong Timing
I love SNL and it is always scheduled on my older dual Tablo. The recording always starts as scheduled, however it always stops some unpredictable time interval later, about one hour or longer. It’s not a problem to simply stop playing the recording, I am just curious do other people have this issue with the old (cheap) dual model, Houston area?
I suspect that the root cause is the after midnight recording end time, but I see this issue with SNL only.
If a program is marked “Live” in the schedule, Tablo will add extra time to the recording. I think this was implemented because of live sports always running over its expected end time.
@khaver’s likely correct. However, it may be viable to check the advanced recording options for SNL on your Tablo.
The default live time extension is 50%. So instead of about 91-92 scheduled minutes, it records about 2 hours 17 minutes.
