Small issue with Onn Streaming TV Box (2021) after upgrading from Android TV 12 to Android TV 14
To all of you with one of the Onn Streaming TV Boxes or sticks, particularly the 1st gen ones from 2021-22, I wanted to report an issue I had when I upgraded to the newly released Android TV 14 from 12.
After upgrading, I couldn’t get my remote to re-pair to the “puck”. No matter what I tried, it is as if the Bluetooth decided to go fatal. I even performed a factory reset, but to no avail.
I threw a Hail Mary pass by pulling the batteries from the remote (yes, I put new batteries in it) and unplugging the puck and leaving them that way overnight. When I got up this morning, I reconnected everything and tried to pair again. This time, it worked right away.
If you encounter this issue, start with removing the batteries and unplugging and wait several hours. That could save you from having to do a factory reset needlessly. I’m not totally sure why that worked, but am glad it did.
And be wary of that update beyond the remote issue. I tried the update on the $19.88 4K box. It is bricked. It will not go past the Google TV logo. Trying a factory reset just gives a bunch of errors about missing files. An Onn Pro updated OK.
Yikes that brings back memories of when the Nexus players were bricked. I lost 3 of them.
I would personally advise anyone about to install the update to power cycle your Onn device FIRST and maybe even pull the batteries once you complete the upgrade process and put them back once it’s time to pair. It’s no guarantee but might help bring the odds ever in your favor.
This has nothing to do with the remote. It’s the box itself that is bricked.
As cheap as these things are why don’t you just go buy the new 4K Plus I have one and it works great and it already has 14 on it
I had a Gen1 Fire TV 4K Max I wasn’t using, so switched to that instead on the one TV.
Update: I was wrong. The pairing on my 2021 Onn 4k box disappears after about 5 minutes of being paired. It is still borked.
Someone on reddit says that Walmart has pulled the upgrade for now, but I’d like to see a source for that information. If true, that would at least mean that whoever in Walmart is over the Onn streaming devices at least KNOWS and acknowledges there’s a problem.
I may just put it in a drawer for a while and try it again later.
Update: It appears that around July 3rd, all of the existing onn streamers got a followup fix for the Android TV 14 upgrade, EXCEPT for the 2021 onn streaming tv device (1st gen). If you have any version of the stick or a 2023/2024 streaming tv device or the onn Pro, you should be able to upgrade to a safe version of 14 now.
If you’re like me and have the onn streaming tv device 2021 1st gen, it appears the wait will be longer. It would be nice to get the factory remote to work again.
I just noticed someone liked this post, so I will provide an update. Earlier this year, I gave my 2021 Onn Streaming TV Box to a co-worker. I told him that it was an issue with the Bluetooth overheating and that he could try to salvage it.
He drilled a hole and put a tiny fan right on top of the bluetooth chip. Lo and behold, he stated that he got the device working again 100% with the factory remote. It is fully working with no firmware update and being on Android 14.
If you have this exact problem, you need a fan to constantly pull heat away from the bluetooth chip.
Did he wait the requisite 5 min before running the flag up the pole???
:wink:
