Have two Tablos on different antenna, on the same network, I can see both in the ROKU, how do I get both to show up in the Ripper on my PC?
Near the top center of the Tablo Ripper screen there are two boxes. The top box is labeled Select Tablo, which should have a pull down arrow so that you can choose which Tablo you want or you can use the lower box which asks for the Tablo Static IP.
Your two Tablos must have different names associated with them to use the top box. The alternative is to use the lower box and fill in your Tablos IP address. Unfortunately that can change any time your router is rebooted unless you go into your router and reserve addresses for each Tablo.
Thank you that worked…
