Antenna Direct: DB8e, wall mount
Homebrew DIY mounted in my attic. Pick up all channels and am 70 miles from Chicago. No pics sorry. Wouldn’t be as cool as @ChrisWilkes
@ChrisWilkes - holy smokes, do you talk to the international space station with that? Â
Really unimpressive Amazon Basics Extreme in my upstairs window.
Same here…just a Mohu Sky mounted in my attic. I say mounted as it is just hanging over a joist via the cable line. Secured with a spot tie.
@ChrisWilkes Nice set-up! Are the
antennae combined to allow one output, and if so, what brand combiner did you
use? What kind of amplifier(s) are you using? Thanks for starting
this discussion, as I’m interested in finding out what kind of antennas work
for folks.
I have two separate Headings to pull in the majority of OTA channels and would like to use two antennae and combine their input. Currently, I’m testing this application using two built-in amplified antennae and 2-way signal splitter (3GHz).  It is working, albeit signal strength varies at times due to the antennas being sensitive to cord movement.  I don’t like the antennas dangling from my ceiling, so I'm thinking of switching from indoor to attic mount type antennae. I've been trying several different brands that will provide a small footprint (due to limited space in my attic) and a decent price point (since I need two+). They will probably need to be amplified prior to reaching the distribution amplifier.
<w:LatentStyles DefLockedState=“false” DefUnhideWhenUsed=“true”
DefSemiHidden=“true” DefQFormat=“false” DefPriority=“99”
LatentStyleCount=“267”>
<w:LsdException Locked=“false” Priority=“0” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Normal”/>
<w:LsdException Locked=“false” Priority=“9” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“heading 1”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 2”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 3”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 4”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 5”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 6”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 7”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 8”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 9”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 1”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 2”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 3”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 4”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 5”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 6”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 7”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 8”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 9”/>
<w:LsdException Locked=“false” Priority=“35” QFormat=“true” Name=“caption”/>
<w:LsdException Locked=“false” Priority=“10” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Title”/>
<w:LsdException Locked=“false” Priority=“1” Name=“Default Paragraph Font”/>
<w:LsdException Locked=“false” Priority=“11” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtitle”/>
<w:LsdException Locked=“false” Priority=“22” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Strong”/>
<w:LsdException Locked=“false” Priority=“20” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Emphasis”/>
<w:LsdException Locked=“false” Priority=“59” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Table Grid”/>
<w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Placeholder Text”/>
<w:LsdException Locked=“false” Priority=“1” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“No Spacing”/>
<w:LsdException Locked=“false” Priority=“60” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light Shading”/>
<w:LsdException Locked=“false” Priority=“61” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light List”/>
<w:LsdException Locked=“false” Priority=“62” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light Grid”/>
<w:LsdException Locked=“false” Priority=“63” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Shading 1”/>
<w:LsdException Locked=“false” Priority=“64” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Shading 2”/>
<w:LsdException Locked=“false” Priority=“65” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium List 1”/>
<w:LsdException Locked=“false” Priority=“66” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium List 2”/>
<w:LsdException Locked=“false” Priority=“67” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 1”/>
<w:LsdException Locked=“false” Priority=“68” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 2”/>
<w:LsdException Locked=“false” Priority=“69” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 3”/>
<w:LsdException Locked=“false” Priority=“70” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Dark List”/>
<w:LsdException Locked=“false” Priority=“71” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful Shading”/>
<w:LsdException Locked=“false” Priority=“72” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful List”/>
<w:LsdException Locked=“false” Priority=“73” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful Grid”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 1”/>
UnhideWhenUsed=“false” Name=“Light List Accent 1”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 1”/>
<w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Revision”/>
<w:LsdException Locked=“false” Priority=“34” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“List Paragraph”/>
<w:LsdException Locked=“false” Priority=“29” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Quote”/>
<w:LsdException Locked=“false” Priority=“30” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Quote”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 1”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 1”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 2”/>
UnhideWhenUsed=“false” Name=“Light List Accent 2”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 2”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 2”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 3”/>
UnhideWhenUsed=“false” Name=“Light List Accent 3”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 3”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 3”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 4”/>
UnhideWhenUsed=“false” Name=“Light List Accent 4”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 4”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 4”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 5”/>
UnhideWhenUsed=“false” Name=“Light List Accent 5”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 5”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 5”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 6”/>
UnhideWhenUsed=“false” Name=“Light List Accent 6”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 6”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 6”/>
<w:LsdException Locked=“false” Priority=“19” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Emphasis”/>
<w:LsdException Locked=“false” Priority=“21” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Emphasis”/>
<w:LsdException Locked=“false” Priority=“31” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Reference”/>
<w:LsdException Locked=“false” Priority=“32” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Reference”/>
<w:LsdException Locked=“false” Priority=“33” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Book Title”/>
<w:LsdException Locked=“false” Priority=“37” Name=“Bibliography”/>
<w:LsdException Locked=“false” Priority=“39” QFormat=“true” Name=“TOC Heading”/>
</w:LatentStyles>
<![endif]–><!–[if gte mso 10]>
<![endif]–>
@streambird it is just two basic Yagi’s about 100° apart combined with a splitter in reverse (aka a combiner). I have tried amplification with many different amplifiers pre & post combining and they all decreased the Energy per bit to Noise Power Density (Eb/No) . I know amplification is highly favored around this forum but as a Broadcast Engineer with professional knowledge and proof with calibrated ATSC spectrum signal monitor, I haven’t found an amplifier that doesn’t decrease Eb/No on a good directional Yagi. Amplifiers will raise the signal up and may prevent loss of lock on a calm day but when the weather gets bad and shakes the trees making multi-path variable and lightning strikes emit noise spikes you will be worse off with an amplifier in place. The smaller of the two Yagi’s picks up just one transmitter and I would like to place a channel pass filter for it so multi-path doesn’t come in for the other transmitters that have a weaker signal coming in on the larger Yagi. I would also like people to know during the hot months some broadcasters may have to drop their power because they can’t keep their transmitters cool enough. Also, transmitters may occasionally loose power and drop down anywhere from 10% to 90% due to a module, tube or klystron failure and you will be at a loss why you are having issues unless you had a reference level measurement and a spectrum analyzer to verify it isn’t you receive equipment. Television stations are not very forthcoming about their transmitter losing 25% power. I am not a fan of any receive antenna than a Yagi. The flat arrays look modern and sleek but I get much better results from a good Yagi. They are much more directional and that helps oveal signal level & reject multi-path signal degration.
May be a few typos, that was a lot from my phone
Forgot to mention the parabolic is a point to point 5 GHz WiFi link. Can’t wait to get the omni 5 GHz up so I can have WiFi throughout the neighborhood.
@ChrisWilkes Thanks so much for the info. It confirms my use of the splitter in reverse to tie the two antennas. Â
@ChrisWilkes Thanks for the info on the transmitters. That explains why some channels drop out occasionally and come back again in a short while.
combination for my area. I finally
settled on two GE Attic Mount Antennas (Model 34792-2), with RadioShack Inline
Antenna Signal Amplifiers attached to each antenna. Funny thing is that during
testing of the antennas directly to the TV, I only needed one of the power supply
units to power the two amplifiers to get the best consistent signal strength needed
to pull in all the major network channels and more in my area. The antennae are
stunted (miniature) looking Yagis. Â Because of the low clearance in my attic, I
had to find an antenna with a small footprint. Â I combined the two antennas by reversing a RCA
DH24SPF Two Way 3 Ghz Bi-Directional Splitter (to make an antenna combiner). Living where I do, I get ABC, NBC, CBS, PBS,
Fox, CW, ION, GetTV, Family, and more with this set-up. There are about 69 OTA
channels in my area, but I only want to see about 25 of these channels. Â I still need to mount the antennas in the
attic, but now that the testing of signal strength is done using the TV first
and then trying them with the Tablo, I’m pretty sure that raising them to attic
level will only maintain or improve the signal strength. I’ve had my 4-tuner
Tablo for about 1 and ½ weeks and the major goal is to stabilize the antenna
strength and the router/Wi-Fi/Ethernet connectivity of the Roku 3s. I do notice
that the Roku 3s are more stable connected directly by Ethernet than by
Wi-Fi. With all of these factors in
place the Tablo works surprisingly well on the TVs.
</w:LatentStyles>
<![endif]–>
