“To enable access to your Tablo when outside your home network you will need to enable the Tablo Connect feature in the settings screen”. My problem is I can’t find this section in the settings screen. Can someone please help.
Thanks
Thanks
It is called “TabloConnect” with a check box for “Remote Access” just above the Guide info.and below the General info sections
My guess is that since not all tablo apps support remote connect those that don’t will not display the option to turn it on.
Do you have a valid subscription? Tablo Connect is only available to those with a subscription.
Zippy and theuser86, thank you for your input.
theuser86 I guess that could it be. No I don’t have a valid subscription. I didn’t see anywhere a requirement for that and it would be somewhat misleading. Do you know where this is documented?
Thanks again for the response
Tablo Connect is a subscription-only feature
Tablo Guide Data Subscriptions
Tablo Connect (out-of-home streaming)
note: x = no subscription | check = with subscription
