Has anyone else had the problem of your Tablo settings, in particular the Live TV rate and the remote streaming rate, and starting screen, charging from what I set them to (typically 1080p for live, and 750K for remote, and Live TV) back to the defaults? Do I need to explicitly “save” the settings? I think this may have occurred after a reboot of the box, but I’m not sure.
The LiveTv rate should never change since it is a Tablo global setting. But the remote streaming rate and the starting screen are different for every device, so anytime you look at a new client, it will be at the defaults.
Good to know, thanks!
