First off I realize there is a scheduling conflict screen and I understand from the manual the blinking blue LED.
+1
May be flashing to the beat of the Canadian National Anthem.
@EJC - Interesting suggestion that makes total sense.
Not sure that the LED is the most effective way to do this though (since some people have their Tablo stashed away in a closet).
Again something I requested many months ago would be to alert the user
* Warning/Error messages<o:p></o:p>
When I go into Tablo interface if an error has happened such as reboot, error recording, etc I would<o:p></o:p>
like to be notified in the user interface.<o:p></o:p>
And even further, email or some other type of notification
Not sure that the LED is the most effective way to do this though (since some people have their Tablo stashed away in a closet).Maybe a notification screen when you log in that you have to clear vs. going directly to the conflicts tab?
I’d prefer that. The nice thing about Tablo is that it can sit ANYWHERE, in a closet, under an end table on a shelf, hidden behind a book case door, etc. It needs only air to breath, antenna cable and a thin low-voltage power wire. It’s tiny and thus - why have it taking up space out in the open. And if you are in a DIFFERENT ROOM, the whole point of Tablo, eh? You’d not see it. We might be downstairs in the larger family room using our phone or my desktop to access the tablo on a shelf upstairs where no one can see it. A notification pop-up or whatever that’s “in your face” until you manually and deliberately dismiss it by chasing a moving target and paying 10 bucks to be very sure you saw it and didn’t just accidentally dismiss it when you hit ENTER or the cat stepped on the phone or whatever.
@TabloTV - The blue led was the first thing that came to mind. However it can be turned off in the settings screen which negates my entire suggestion.
IFTTT integration that sends you a notification or text message if there is a scheduling conflict maybe?
A text message would be ideal, since I may go a few days without firing up an app.
@tablotv a push notification would be great. Or a text message or email. Text and email are probably easier since the tablo has to sync to see changes on the tablo itself. Or Maybe a popup in the app that tells you there are conflicts after you sync.
This should be a feature.
@tablotv a push notification would be great. Or a text message or email. Text and email are probably easier since the tablo has to sync to see changes on the tablo itself. Or Maybe a popup in the app that tells you there are conflicts after you sync.This should be a feature.
+1 definitely a needed feature.
Can we get a priority list so shows that we don’t care about can be bypassed on a conflict without input? This is something most all DVR systems have.
I haven’t experienced any errors yet but a pop-up following sync would seem to be good way to alert users to potential issues.
All good suggestions that we would like to incorporate. I’ll add these to the request list.
