Just setting up a new Tablo Dual HDMI and I got the Wi-Fi connected Okay and going thru the setup I can’t get past the Zip Code part. It keeps coming back with Save Location Failed. I put in about 6 different zip codes. I can get about 80 channels but it can’t locate my zip? Does anybody have this problem? What do I do now?
Ok, I live in Kenosha tried 53140 42 43 44. And a couple of Chicago zips 60656 60601. Milwaukee 53204 53215. Maybe someone is in the area that uses a good zip for this.
Well, I don’t know what happened. After I unplugged everything on Saturday when it couldn’t find my zip code I plugged everything back up this AM and went thru the steps and it found my zip code. What a relief. I was just about to call support. It downloaded an update and install it. Scanned and found 76 channels. Now I’m gonna play around with it.
Hi @Gus - Glad to hear you got sorted! It sounds like perhaps your Tablo may have lost internet partway through setup. In that case, things like zipcode lookups would fail.
