Can you use Tablo with a Samsung television? If not, is there a plan in the works to make it compatible?
At the moment, you would need to add an external device like a Roku or FireTv to your Samsung TV to make it work with a Tablo.
Iâm waiting for the Samsung app too, but at least they say itâs âcoming soonâ.
I saw there was once a Samsung TV app which was discontinued. I am curious about why specifically it was discontinued (i.e., not a generic or blanket answer without the details). Nevertheless, I have a legacy Tablo. If the app does come to Tizen, I hope the legacy devices will be supported. My legacy Tablo still does exactly what I originally purchased it to do. I still use the legacy commercial skip feature as well as remote connect. I would lose those upgrading to a 4th generation device, so I am not interested in upgrading at this time. I use Roku in the meantime.
Some âsmartâ OS providers are better at dealing with developers than others (hint: one that doesnât do well is Samsung).
Yes⌠sure⌠âsoon!â
