I’ve been using 14" square OTA mounted in the window. I’m looking for a better signal and am considering a roof mounted antenna. Recommendations please
What works for one may not be ideal for another. You’ll need what works best for your setup, location and needs.
Antennas aren’t necessarily one size fits all, but really, there isn’t a substantial difference between many of them.
If you can copy/paste the report from Rabbit Ears (it doesn’t give personal information, only the distance to the towers, the directions, frequencies and ridges the signal has to cross:
