Have a new Tablo Dual and Roku Ultra. Installation went without a problem. Using a Asus router, Tablo is connected by Ethernet and Roku connected over WiFi. Roku Tablo app can not find and connect to Tablo.
Have tried all the listed troubleshooting tips. Resets, reboots, power resets, uninstall/reinstall of all hardware and software. No errors I can see except Roku keeps coming back to the opening Tablo app screen when search for Tablo ends with no connection.
Ethernet is and is where you will want to eventually wind up, but I think I would try it (making sure that both the Tablo and Roku are using wi-fi on the same band (either both on 2.4 or both on 5). If they then “see” each other, you could try going back to ethernet.
Note: The Roku does not currently support initial setup of your Tablo. You’ll need to complete this via one of our other apps (iOS, Android or web). For instructions on installing the Tablo app on your Roku device, click here.
Well that worked, putting both the Tablo and Roku on the same band. This gave me the clue I needed to figure out the problem. I had my Roku on a guest WiFi channel that had access to the rest of the LAN blocked, which of course included the Ethernet ports. So once that was enabled everything is working great. So thanks for helping me out.
You should keep your guest WiFi network separate from your internal network. Did you change the WiFi connection on the Roku? I usually disable my guest WiFi network.
Yes, my Guest NW is separate, just didn’t think about that the Roku was on it and blocked from the Ethernet port the Tablo was on. Now everything is working perfectly.
