I have a Roku 3 original in the living room, connected to my Linksys EA3500 on 802.11N 5 GHz network. I also have a Roku LT in the bedroom, which is on 802.11 N 2.4 GHz network. Both Rokus and the Tablo, along with my phone, and all computers all have DHCP Reservations. Since putting the Roku 3 and Tablo on 5 GHz it hasn't crashed.
When the disk was almost full I was getting weak signal while the scan on the phone showed 4 green circles. I put it on automatically delete if needed for space and since then, the weak signal error is gone.
I am only using a Mohu Leaf 50 antenna for the Roku.
- The repeating segments are likely due to poor OTA signal. See here:
The old Roku 3 Model 4200 will perform better than the Roku LT with the new channel. Look into the new Roku 2 Model 4210, it’s the same hardware was the old Roku 3 so for the price it’s great. New Roku 3 Model 4230 has the voice search remote.
Yes upgrading your wireless router if you have your Roku on WiFi will likely increase performance in terms of how fast it responds. What is the exact model of your current modem / router?
If you want to upgrade for the price and performance, I recommend you get a TP-Link WDR3600. I have one and it works great. Then you can also add your new Roku 2 or 3 to the faster 5 GHz band. Read more about it here.
All good suggestions above. We’re also working on speeding up the experience on the new Roku channel.
@beastman - great info, thank you. Some follow-up questions:
Do you notice any performance difference while navigating the Tablo channel on the Roku 3 compared to the Roku LT? (Would you be willing to time similar operations on both devices and see if there’s a difference?)
- When you say “Since putting the Roku 3 and Tablo on 5 GHz it hasn’t crashed.” are you referring to the loading/repeating problems I mentioned originally, or are you talking about something else? What do you mean by “crash?” (I ask because I periodically get “no tablos found” kind of messages that only seem to resolve themselves when I unplug and replug the Tablo).
Sometimes the Roku would reboot and other times the no Tablo detected. Weak signal never happened on 5 green circled but for on 3 orange.
@user86
My Internet:
FIOS 50/50 speed. My gateway router/modem is connected by a cable (not the WAN)
I’m thinking about replacing my router and am looking at the TP-Link WDR3600, the one you recommend.
However, my current “router” also contains the modem.
So, I have to buy a modem also ?? If yes, which one do you recommend.
Thanks
Chas
@cthompgh, you can just set your current FIOS modem into “bridge mode” and attach the new router to it. You don’t need a new modem as well. Just google Bridge Mode and your router to see how it’s done.
@snowcat is right per usual.
You put the FIOS modem/router combo into bride mode which makes it operate just in modem mode. Then you connect the WAN port on your new router to one of the LAN ports on your FIOS modem (can technically be any of the 4 LAN ports, but I usually use the one numbered 1 just to be sure).
Will try it
Great - thank you very much!
As someone who has 3 Roku 3’s and 1 Roku LT, I can tell you the Roku 3 is much better. Not only does it have dual band WIFI, but it has dual radios, meaning that theoretically, it should connect twice as fast even on 2.4 GHz (300 mbs theoretical max vs 150 of the LT).
The channel is much faster on Roku 3 as well.
I regret buying the LT myself, wish I had picked up a 4th Roku 3.
I’d get one of those new Roku 2’s that have the same processor as the Roku 3’s. They are cheap! $60 at Amazon.
The LT let you use the Roku on TVs that do not have HDMI as well as HDMI. The Roku 3 is HDMI only.
You are correct. But the Roku LT is old school, the current Roku 1 Model 2710 has composite video out, as does the recently retired Roku 2 Model 2720 (retired in April 2015). You are better off buying those than a LT.
