Using two compatible Roku devices in close proximity to the Tablo device that will not display OTA returning to guide however work perfectly in another room. Why?
It’s likely that the Rokus are set for automatic audio settings and that it changes on each TV.
Yes, the OS14 bug seems to be related Roku/TV combinations. A Roku may work fine on one TV but not on another. When this all started a few weeks ago I played musical Roku, switching devices around until I got nearly all of my setups working. Out of seven setup all but two are working.
Thankfully, the fix from Tablo is starting to be pushed out now.
I noticed today there was a firmware update to cure the issue, and did.
Thank you
