I have a 4 channel tablo and 2 rokus. They are all connected on a wired ethernet. I updated the tablo to 2.2.10 yesterday. Now, on both rokus, the live tv guide just shows “Loading…” on all channels.
I have tried:
Rebooting the tablo, the rokus, and the router.
Forcing a guide update on the tablo
Uninstalling the tablotv channel from the roku, and reinstalling it
Tablo firmware 2.2.10
Using Roku 4 Wireless:
Channel 2.0.build 20
Channel 2.1.build 33 (aka Beta)
and both work fine.
My Router is a TP Link Archer C7, which several of us recommend. What is your Router? Other Routers are also good, but if it is going to be wireless, then AC1700 or faster = better Tablo experience.
Have you tried wireless? Sometimes wireless on Roku works when Ethernet connected doesn’t. I think they just changed the driver. I don’t know what the other beta testers use, but know I use ONLY WIRELESS EVERYTHING
I just did a factory reset, and all is working again. I have to say though that I’m losing my patience with Tablo. The “wife approval factor” is very low. In her words, “why can’t it be like the Sonos and JUST WORK.” It really seems to be more of a beta product with hardware that is not fast enough to provide a “snappy” user experience.
I’m starting to lose my patience as well… Now, after installing the new firmware 2.2.10, I’m consistently getting the ‘Weak Signal’ and rebooting the Tablo isn’t working now… This is so frustrating…
When a new recording is scheduled to begin, 2.2.10 seems to “assign” a tuner without checking to see if that tuner is already in use. This produces an error message and halts the currently executing task. Hope this is a fixable “bug”. Thanks.
I am getting “Weak Signal” now on a regular basis since upgrading to 2.2.10. This release is a complete disaster. I can handle ff/rewind issues, etc. But flat out failing to record or even let you view live is making my Tablo 4 tuner virtually useless.
How do I revert back to 2.2.8. It was solid for me on this front. I’ve seen people ask, but no response from support if this is possible. There is always a try this or that.
As far as I know, there is no way to revert back to a previous version. However, I need you to try this, go into settings, scroll down to the ‘Guide’ section, click on ‘Edit Channel Lineup’, then click on ‘Rescan’, then once the rescan has completed, Click on ‘Add to Guide’. Now, once the ‘Add to Guide’ has completed, now try a channel that was giving you the ‘Weak Signal’ message…
looks like this is happening to more and more people. I’ve been getting booted out to the channel guide while watching live TV. When selecting the program to continue watching I then get the weak signal message and then it reboots by itself and then I can continue watching.
As Mastewman stated, rescanning the channels should definitely be done after the upgrade. However, all of my channels came back with green / 5 dots. It moderately helped the situation.
