I have two roku 3s that both have the same problem:
- Pick Tablo channel
- Recordings
- Select Big Bang Theory
- Episodes
- Loading… Please Wait…
- Channel crashes.
- Back to Roku’s My Channels
Yes, this a new problem with the Tablo and the Roku. There is a thread about it already, but the issue appears to be with shows that have multiple seasons recorded or shows that don’t have any current episodes.
The Tablo folks are investigating.
Thanks for the info. If mutlple seasons is a problem then my series recordings of the Simpsons since the day I bought the Tablo should have been a problem vs Big Bang Theory’s 2 seasons I have recorded. But…oh well.
My Simpsons crashes every time I select an episode to play.
I am not having this problem with my Roku 3 with multiple season shows. Is there a way to check which version of the Roku channel I have installed?
I was having this problem with Big Bang (which had multiple seasons). Clicking on episodes would cause the Tablo Roku app to kick back to the main Roku screen. I deleted the old seasons (leaving only the current), problem solved. I have other recordings with multiple seasons/older shows, but none of them cause the failure.
I can’t see a way of seeing the version.
@snowcat, @theuser86 - you can see the version by hitting the * key on the Roku remote (when on the main Tablo menu).
I do not have this issue either. I went through the following steps:
I am having problems with my roku 3 when playing some recording!
I can also make it crash with less than 10 recordings, but the show had to be old enough to not be visible on the default Roku recordings screen. I have only about 6 recordings of Crossbones, but it crashes immediately after I select Episodes.
