I have noticed there are two roku apps for Tablo which one should I use, I just bought a tablo it is 2023 model
If it’s the white 4th gen model, you need the app with the blue background.
The white app is for older (Legacy) models and will not work with the new Tablos.
thanks
You’re very welcome!
