Yes, the 4 is full of glitches. I had almost no issues with the legacy unit.
Same here.
Iām having the same issues. Tried all the suggestions with no luck.
Same here, started today
This problem also started up today. Two different TVs with two different latest generation Rokuās. Besides using Roku, I am trying to watch the over the air NBC channel for Monday Night Football. It plays anywhere from 30 seconds to five minutes before going back to the main page.
Iām experiencing the same.
Iām having an issue where I am watching recordings on my Roku devices and they stop playing intermittently and often (for the past two days). This is happening on two Rokus, with no DTS, only Dolby on all settings that have DTS as an option. Iāve also unplugged and replugged power to the Tablo and the Rokus. The same recordings are working normally on an Android phone and Android tv device, so it seems to be Roku related, but I donāt know for sure. Anyone else having this issue, any suggestions? Thank you.
EDIT: Thank you for moving my post to this thread, Iām glad youāre working on this issue. Both of my Rokus are running software version 14.6.4 with build 9915. One is a Roku Streaming Stick 4K and the other is a Roku Express 4k+.
Sounds the āAudio Compatibility Modeā work-around is no longer working around.
Same problem here, on 2 TVs, one playing NBC NFL football game live and the other playing the CW live. Tried to clear cache, restart Roku, reinstalled app, still no fix. Didnāt restart Tablo because Iām recording Big Brother on CBS. 4 tuner Tablo. Tablo any suggestions?
Having this issue on Roku model 9102R running 14.6
Model: 3820R2 - Streaming Stick 4k
Software version 15.0
They workaround that is working for me is to pause the show for 30 seconds and then resume. I donāt know if this would work for recorded shows though.
Yet another user experiencing this same infuriating issue: Any content plays for from 5 seconds to a few minutes before stopping, falling back to the content screen.
Exact same failure occurs across multiple Roku devices and OS versions:
Roku Version: 1.2.0-734366
Roku Model: 3900X & 4801RW
Roku OS(es): 14.6.4 & 15.0.4
I have the issue on two Rokuās
Roku Ultra LT
Model 4662RW
Software version 15
Roku Ultra LT
Model 4662RW
Software version 14.6
My system started glitching today. Iāve got a Roku model 4660X (Roku Ultra) running OS v15.0.
Thank you for this post! I can much more easily tolerate an acknowledged bug.
All of my Roku devices are exhibiting behavior where it will begin to play a live stream but will freeze and return to the main menu after a minute or so. My primary TV uses a Model 9102R - Roku Streambar running Software version 14.6.
Second TV has a Roku Ultra also running 14.6 on a Vizio TV and Vizio soundbar connected via optical cable.
The last one is a Roku LE running 14.6 with a Vizio Soundbar.
I attempted all the suggested fixes regarding audi0 settings on both the Roku and in the Tablo app and none seemed to fix the issue as of 9 pm. At the moment (11:45), I cannot duplicate issue. Perhaps it takes time for a setting to propagate. I will attempt this again tomorrow by changing one setting at a time and allowing some time to pass in an effort to replicate the issue and will update you if I find anything.
14.6 - so far this morning this issue hasnāt presented itself.
Roku Model - 4662RW - Roku Ultra LT
Roku Software - 14.6
Patience with constant issues - 0
Roku TV. Model 75r8bx. Software version 14.6.4. Application version 1.2.0-734366. Tablo firmware 2.2.54
Was planning to buy one of these for my RV but I use all Roku. Seems like a real mess and not sure I should bother.
