Replacement Tablo
Gen 4 user. Had my Tablo replaced. Hooked up external hard drive that was connected to the old Tablo. Content recorded on the old Tablo is not showing up. New Tablo is showing hard drive half used. I’m assuming the content is still on the hard drive. Is there anyway to access this content?
I do not have a 4th gen, but for the legacy units there was a specific process you could do to move a hard drive from one Tablo to another. You should check to see if the procedure is available for 4th gen.
Don’t leave the Tablo on overnight, the housekeeping function may remove the old recordings.
EDIT: looks like it is not possible, see this support article.
Thanks! I called Tablo support and they say it’s not possible.
