I am trying to setup port forwarding on my Cisco 2600 to use remote access with the Tablo. I already have port forwarding setup to access security cameras and I am using the ip nat command. I am getting the green check mark for port 443, but red ! on 80 and 8887. Any thoughts on what I can do to fix this? Commands I am using on my router:
ip nat inside source static tcp 192.168.1.182 21112 interface FastEthernet0/0 8887
ip nat inside source static tcp 192.168.1.182 21110 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.1.182 21111 interface FastEthernet0/0 443
