Has anyone had any luck setting up their Remote Access on Frontier?
I’ve searched and found a number of people posting assistance with setup for providers, but I have yet to find a walkthrough specific to Frontier.
I’ve done some searching on YouTube and found some general videos on Port Forwarding dating back to the U-Verse days. (I have a 2Wire router that dates back to the U-Verse days, before Frontier took over in my area. Same equipment, different corporate overlord.)
Basically, when I try to turn on Remote Access, I get the expected message “Your router requires manual configuration.” It lists two ports that need to be adjusted.
When I go into my router settings, I can get one of those ports configured, but when I try to add the second port to the definition list I get an error claiming: “The port(s” that were entered overlap with port(s) that are already being used by this application."
I’ve tried deleting the configuration and setting them up in the opposite order, with the same error result.
I’ve even tried setting each port up as a separate setting, but that doesn’t seem to work either.
I’m done struggling with it for today. I figured I would post a message to see if anyone else has tackled this issue already. (With luck, someone might have an answer for me when I get back to it later this week.)
Thanks in advance.
ELK
