We just got our Tablo 4-Tuner and I don’t see where under settings to turn on for Remote Access… Help I don’t want to miss the game.
Are you already connecting away from home? Or are you at home?
Read this:
I am at home. I’ve already read the tablo connect & port forwarding, but I do not see where I can check the button to connect remotely
If there is no check mark that means it is setup correctly already. Try using your LTE data on your phone to test.
What client are you trying to connect remotely FROM?
You should see a section(in Settings) similar to the included photo. (this is iOS).
this:
[/quote]
