Remote access used to work automatically but after a power outage, the remote access no longer connects. I’ve been trying for months to get it going with forward porting. I have absolutely no idea what I’m doing wrong. Below are screen grabs of what the Tablo says and how I programmed it as per their how to guide and nothing ever works.
Maybe provide more details on your configuration, type of router and ISP. Maybe someone with a similar router/ISP maybe able to provide more help.
You have 4MBbs set can your ISP provide that? Also the graphic of the router config page has two circles on the left are they supposed to be checked/filled in/selected?
Your settings all look correct (I have used Netgear routers for my Tablo). My only suggestion would be to disable UPnP and reboot your router. Then go to the Tablo and see if it works.
