I’ve read through the previous related threads and I’m pretty sure I have everything set up right, but I still cannot get the remote access feature to work.
Here is my setup:
-Fiber into the house goes to a modem (not a router just a modem)
-Modem connects to Google Wifi
-Google Wifi connects to 4 port ethernet switch
-Tablo is hardwired into the 4 port switch
I attached screenshots of my settings. Can anyone help? I need to get this set up or my wife will make me go back to DirecTv. Any suggestions to try?
I have Google Wifi and Tablo and no issues getting remote access setup. Sounds like we have similar configurations.
Modem (not acting as a router)
Google Wifi
Switch
Tablo hardwired to switch
DHCP reservation for tablo 192.168.86.x
Double-check that the public_ip value shown at https://api.tablotv.com/assocserver/getipinfo/ matches the WAN IP shown at https://whatismyipaddress.com/. If they don’t match, try power cycling only the Tablo and test again. (Note: I originally suggested comparing the public_ip value with the WAN ip value in the Google Wifi App but that App doesn’t seem to show the correct WAN IP.)
Yes - you may want to edit the post to remove your full public IP address. (The IP range 100.70 is part of a shared private range that ISPs can use).
I checked my Google Wifi App and I have UPnP disabled. If it isn’t already disabled maybe try turning it off. Maybe a conflict between port forwarding and UPnP??
Try reaching out to @TabloTV or @TabloSupport to see if they have any ideas before you return your Tablo. I’ve had mine for 5+ years with no regrets.
I wonder if you 208.x.x.x address is mapped at your ISPs router to the 100.70.x.x address on your router. Google Wifi is creating a port forwarding rule for the 100.70.x.x but Tablo needs one at the 208.x.x.x address which is at your ISPs router. I hope that makes some sense.
Yes my point is if the Google WIFi router is not reporting the WAN IP address as the same IP Address as What is my IP then there is some networking issue. Maybe “double NAT”. For why double NAT is a problem, take a read of the links below.
So apparently it’s a provider issue. All the homes in my area share an IP address and the carrier uses their on NAT to assign IP addresses. The only way to get around it is to purchase a static IP address. Thanks to everyone for the assist. At least we discovered and resolved a new issue.
Per Reddit Post:
It’s not a problem with the device inside your home; it’s an issue with the Metronet network. Your home connection shares an IP address with other people’s home connections, and you can’t work around that level of NATing. All you can do, if you want to be able to access local resources from elsewhere on the internet, is to purchase a static IP address from Metronet for (I believe) $10/month.
