I have Century Link as an ISP and added an Eero mesh network. Eero doesn’t support using the Century Link Router in bridge mode so I had to double NAT to get it to work. I’ve tried setting up the Eero ports for port forwarding with no result. I’ve seen suggestions that the Century Link router needs to have the port forwarding set up. I haven’t tried it yet as it’s a pain to direct connect to the router in the basement (WiFi is disabled).
If I do this will the Tablo work with remote access- I’m skeptical as the Tablo is on the Eero network. Any suggestions?
