REMINDER - Legacy Network-Connected Users Must Update By May 22
UPDATE - Users still on 2.2.42 must contact support to arrange for their device to be updated remotely.
Version 2.2.60 contains a critical security patch that must be processed by May 22, 2026. (This patch was already included in firmware 2.2.58.)
If you do not update your Tablo’s firmware before that date, connectivity between your Tablo device and Tablo servers will fail, impacting your experience in the following ways:
  • Access to All Subscription Features Will Expire
    Since your Tablo won’t be able to verify its subscription status, access to all subscription-enabled features will expire, including extended 14-day TV Guide Data, series and advanced recording features, Tablo Connect for out-of-home streaming and Automatic Commercial Skip.
  • Connectivity Through Some Tablo Apps May Fail
    Tablo apps that rely on our servers to authenticate new connections may fail to discover or connect to your Tablo device. This could affect Tablo apps for Samsung and LG smart TVs, Windows 10 and the web app.
  • Your Tablo Won’t Receive Updates
    Tablo servers also manage firmware update notifications and downloads. If your Tablo cannot connect to our servers, it won’t receive any future firmware updates.
Processing this firmware update will allow you to continue enjoying your Tablo beyond May 22nd.
FAQs About the 2.2.60 Critical Security Patch
  • Which Tablo models require a firmware-based critical security patch?
    The following legacy network-connected Tablo models require the application of a firmware-based critical security patch by May 22nd, 2026: Tablo DUAL LITE, Tablo DUAL 64GB, Tablo DUAL 128GB, Tablo QUAD, Tablo QUAD 1TB and the original 2-Tuner and 4-Tuner Tablo. If you have updated to firmware 2.2.58 or 2.2.60, this patch was already applied to your device. This patch isn’t required for Tablo DUAL HDMI, QUAD HDMI or 4th Generation Tablo devices as they use more recent and up-to-date security credentials.
  • What if I missed the deadline to update my Tablo?
    If you have failed to update your legacy network-connected Tablo device and your experience is now negatively affected, please contact support to arrange for your device to be updated remotely.
  • What does the critical security patch update do?
    When Tablo devices connect to the servers at Tablo HQ, it uses specific security credentials to ensure that communication between the server and the device is protected and encrypted. The security patch in firmware versions 2.2.58 and 2.2.60 replaces older security credentials that are expiring with newer ones, extending the life of your legacy Tablo device. If you have already updated to firmware 2.2.58 or 2.2.60, your Tablo is now using the newer security credentials.
  • Was my Tablo or network at risk without this security patch?
    No, your Tablo or home network was never at risk. Imagine this patch as your Tablo’s passport to Tablo HQ, which is expiring on May 23rd. The ‘border’ remains secure, and ‘passports’ included in previous firmware versions, including 2.2.42, will remain valid until then. But, if you don’t update your firmware to receive a new ‘passport’ before then, your Tablo will be ‘refused entry’ and won’t be able to obtain a new ‘passport’.
  • Why couldn’t Tablo just keep the old security credentials?
    Security credentials for devices and servers have set expiry dates, just like passports. Setting expiry dates is one of the best practices Tablo uses to help reduce overall security risks.
  • I don’t want to use the new 4th Generation Tablo apps. Do I still need to update?
    Yes. All legacy network-connected Tablo devices must update by May 22nd. Even if you never plan to enable the Legacy Transition and use 4th Generation apps, updating will ensure that connectivity between your Tablo device and Tablo servers can continue. Without it, access to all subscription-enabled features will expire, connectivity through some Tablo apps may fail and your Tablo will no longer be eligible to receive updates. Updating to 2.2.60 WILL NOT prevent you from accessing your Tablo through the legacy Tablo apps you use today or alter the features available to you within legacy apps.
  • I have a different Tablo model. Does my device need this security patch?
    This patch isn’t required for Tablo DUAL HDMI, QUAD HDMI or 4th Generation Tablo devices. As comparably newer devices, they use more recent and up-to-date security credentials.
Just wondering if somebody had aTablo that was unused, maybe sitting in a closet, and not updated. If they connected after May 22, would it still be able to update, or would it be basically bricked?
Great question @andyross . I have an OG 2-tuner that hasn’t been powered up in years, but will dig it out if it’s going to get bricked. @TabloTV
Update: connected my OG Tablo to the network and powered it up (no antenna or storage attached). I used my.tablotv.com to access it, went through 2 firmware updates and am now on 2.2.60 - very easy process.
With the old firmware the Windows 11 Tablo app could see the OG, but could not access it - would just kick me out of the app. Once I was on 2.2.42 the app worked fine (did the final firmware update to 2.2.60 via the app).
I haven’t used my Legacy Dual Lite in over 3 years. I powered it up, connected it to the network and used the Legacy Roku app and it updated to 2.2.60 without a problem. I wish I had seen this deadline sooner though, I could have updated another Dual Lite I own, but it’s in another location and I’ll not be there until next week. But since I’m using the 4th Gen units exclusively, the Legacy units were just a backup anyway.
My tablo has firmware 2.2.42. It tells me it is up to date.
You must update today. If you don’t update your legacy Tablo immediately, you won’t be able to process any updates moving forward.
Your Tablo is likely an HDMI model.
I have a Tablo Dual Lite and it says I have version 2..2.42. when I click the Check for Firmware Version thru my Roku App, the wheel spins but it never updates to 2.2.60. This is a NETWORK version Tablo NOT an HDMI version. So, why won’t it update?
I just found out that the answer is YES.
I tried updating an old Legacy unit today (22nd), which was previously factory reset, and it will not connect to the servers or complete the setup process. It’s bricked unless Tablo extends the firmware availability or allows for offline updates via download.
UPDATE: I contacted Tablo support and they sent out the firmware update directly to my device. It’s functioning properly now.
I’ve been trying to update a Dual Lite Tablo today (22nd) but it won’t go through because I can’t get past the setup process
