On the Tablo app on my android phone in the settings under the subscription tab there are two buttons. One is “manage” the other is “refresh”. What does the “refresh” button do?
Jim
Jim
I would assume that if you change your subscription status while on any Tablo web app, you can just hit refresh to see it change. It may be the least used button on the interface.
It can also be used to trigger a guide data update. For example, if you’ve lost power or internet for a few days you’ll be missing a few days of guide data (which is downloaded during nightly maintenance). That can get you caught up ASAP.
That is good to know. Will make sure I use it when it is time for Monthly subscription renewal. My Tablo seems to forget to all my scheduled recordings until I do a manual update right after the end of the month.
