4th gen, 4 tuner, using internal storage for a couple years now. I just noticed that all but the last couple days of recordings are gone, even ones I locked. What happened!!!
Sorry you’re running into that @Keith15335,
If you haven’t already, doublecheck to see your missing recordings are no longer in All Recordings.
If they are not, do you have an external drive? If so, has it connection become loose?
If that doesn’t help, reach out to, Tablo Support. They may be able to help.
