Recordings go back to beginning
I have a Tablo 4th Generation and am using the app on my LG OLED TV 2024. Sometimes, but not always, when I go to a recording that I have paused to go back to later, and I exit the Tablo app. the recording goes back to the beginning instead of resuming where I left off. If it is a long recording, like a football game, it takes a long time to get back where I was.
Is there a workaround for this?
Hi @dadrad51 ,
Does this happen if you’re watching a show that’s in the process of being recorded or with a fully recorded show?
It happens with fully recorded shows.
Happens to me when watching any completed recording in my Library. I submitted a ticket.
I’m using an Apple TV.
Mine is an LG, but I imagine the apps are similar. Where did you submit your ticket, and I will do the same for LG?
I discovered that all Tablo apps are not the same. I was using the Tablo app for my LG Smart TV. That was a mistake. I already owned a Roku Ultra that I was not using, because the LG already had the ones I was using (Plex, Prime Video). I plugged in my Roku and added the Tablo app, and voila! I could turn on subtitles while watching a recording. I could pause videos and go to another app, and restart the video where I left off. The LG Tablo app always went back to the beginning instead of where I left off.
If you are having trouble with the Tablo app on your smart TV, you should get yourself a Roku.
Go here to start your ticket.
OK, I started a ticket for the LG app. But I also started using the Tablo app on my Roku Ultra, which solves that problem and a couple of others for me. I just don’t think their systems department puts a very high priority on versions of the Tablo app for smart TVs.
