Have a Tablo 2-Tuner. First few days using it have good signal strength. My recordings are correct but they seem to all have the same wrong channel listed with their info. Anyone else having this issue? Thanks
Can you clarify what you mean by ‘wrong channel info’? An example would be great!
I had the same problem, for me it was always showing CH 14 no matter which channel the show was recorded from.
It started working correctly after I re-scanned and updated the channel list in settings.
